вот мой скан авто, за который отдельное спасибо Oleg3110_78:
[spoiler=]Sunday,15,March,2009,16:41:32:26365
VCDS Version: Beta 812.4
Data version: 20090214
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No: 06A 906 033 GG
Component: SIMOS71 1.6l 2V 1025
Revision: --H04--- Serial number:
Coding: 0004071
Shop #: WSC 00066 000 00000
1 Fault Found
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 006 - Short to Plus - Intermittent
Freeze Frame:
Lambda: 25.0 %
Lambda Factor: 1.000
Voltage: 0.420 V
Speed: 0.0 km/h
Readiness: 0000 0000
Address 03: ABS Brakes Labels: None
Part No SW: 1K0 907 379 AQ HW: 1K0 907 379 AQ
Component: MABS MK70M 0105
Revision: 00H32001
Coding: 0016641
No fault code found.
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 5K0 907 044 BD HW: 5K0 907 044 BD
Component: Climatronic H14 0608
Revision: 00003001
Coding: 0000000000
Shop #: WSC 00066 000 00146
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_VW35.rod
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5K0 937 086 HW: 5K0 937 086
Component: BCM PQ35 M 008 0019
Revision: BC008001
Coding: 40000A3A902D02E040000080400001200300008870008D605CC000000000
Part No: 1K1 955 119 E
Component: Wischer 04080 21 0501
Coding: 009795
1 Fault Found
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 6
Reset counter: 66
Mileage: 4913 km
Time Indication: 0
Date: 2003.14.13
Time: 15:34:26
Freeze Frame:
Term 15 On
Voltage: 14.50 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 2J AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2E7RP
Coding: 0012874
Address 16: Steering wheel Labels: None
Part No SW: 1K0 953 549 CT HW: 1K0 953 549 CT
Component: J0527 053 0111
Coding: 0000001
Address 17: Instruments (J285) Labels: None
Part No SW: 5M0 920 860 A HW: 5M0 920 860 A
Component: KOMBI H08 0020
Revision: V0008011 Serial number:
Coding: 170700
ASAM Dataset: EV_KombiUDSMM9RM10 A04010
ROD: EV_KombiUDSMM9RM10.rod
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 050609F2000024
Coding: E9807F06000202001002
Address 25: Immobilizer (J334) Labels: None
Component: IMMO H08 0020
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
ROD: N/A
No ASAM data available for this controller:"EV_ImmoUDSMM9RM10" .
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000567198720
Coding: 0000180
Shop #: WSC 15600 935 77099
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 68 2901
Revision: 00H15000
Shop #: WSC 02069 000 90108
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 09051011594602
Coding: 0000180
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 013 0036
Revision: 00000000 Serial number: VWZ1Z2I6192267
Coding: 0500040004
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000004105565
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000004099038
Coding: 0000144
End ---------------------------------------------------------------------
уж очень интересует что у меня с индикатором на приборке? Дядя Федор, глянешь? :)
прокомментирую маленько, на новой приборке в МФА скорость дублируется но пишется в милях, надо понять в каком блоке и что переключить
все файлы скинул на тезку пусть закинет себе и пробует прочитать снова walex свяжешся с Олегом.
walex,
Если не всплывет подсказка попробуй изменить код на 170100 (Это по аналогии со старой приборкой).
Если всплывут подсказки ОБЯЗАТЕЛЬНО сделай скрины и выложи.
Если будет длинное кодирование - тоже сделай скрины.
кстати "Контроль косвенного давления шин" я Валере активировал без подсказки (с калькулятором по аналогии со старыми блоками) :)
Товарищи, вот есть два автоскана, если со вторым проще, то по первому особо интересует есть ли ошибка по неработающим попогреям...
поможите кто чем сможет...
VAG-COM Version: Release 704.1
Data version: 20071016
Tuesday,09,February,2010,12:19:17:21461
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72
VIN: WVWZZZ********* Mileage: 58110km/36107miles
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Malfunction 1010
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
Address 01: Engine Labels: None
Part No: 06A 906 033 EM
Component: SIMOS71 1.6l 2VG 9428
Coding: 0000071
Shop #: WSC 24200
4 Faults Found:
Freeze Frame:
Lambda: 25.0 %
Lambda Factor: 1.008
Voltage: 0.420 V
Speed: 0.0 km/h
Lambda: 25.0 %
Lambda Factor: 0.992
Voltage: 0.420 V
Speed: 0.0 km/h
Freeze Frame:
Lambda: 25.0 %
Voltage: 0.420 V
Speed: 0.0 km/h
Lambda: 25.0 %
Voltage: 0.420 V
Speed: 0.0 km/h
18683 - Oxygen (Lambda) Sensor B1 S1: Negative Lead: Open Circuit
P2251 - 007 - Short to Ground - Intermittent
Freeze Frame:
RPM: 2048 /min
Mass Air / Rev.: 92.6 mg/str
Voltage: 2.100 V
Bin. Bits: 00000110
28793 - No Communication with ABS Brake Control Module
U0121 - 009 - Open or Short to Ground - Intermittent
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00000001
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 1K0-907-044.LBL
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
1 Fault Found:
00819 - High Pressure Sensor (G65)
Address 09: Cent. Elect. Labels: 3C0-937-049.LBL
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Coding: A1078E2700041550470A00000F00000000095D035C0000
Shop #: WSC 00066
Component: Wischer 231006 020 0501
Coding: 00065535
Shop #: WSC 00066
9 Faults Found:
00156 - Control Circuit for Windshield Washer Pump
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 57229 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.35 V
ON
ON
OFF
OFF
OFF
01259 - Fuel Pump Relay (J17)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 254
Reset counter: 106
Mileage: 55393 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
00924 - Relay for Headlamp Cleaning System (J39)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 5
Reset counter: 67
Mileage: 55392 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.55 V
ON
ON
OFF
OFF
OFF
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 57672 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.25 V
OFF
ON
OFF
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 96
Mileage: 57939 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.60 V
ON
ON
OFF
OFF
OFF
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 57672 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.25 V
OFF
ON
OFF
OFF
OFF
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 94
Mileage: 57851 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 11.75 V
OFF
ON
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 5
Reset counter: 107
Mileage: 56887 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.80 V
OFF
OFF
OFF
OFF
OFF
00926 - Terminal 30
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 2
Reset counter: 94
Mileage: 57851 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 5.00 V
OFF
ON
OFF
OFF
OFF
Address 17: Instruments Labels: 1K0-920-xxx-17.LBL
Part No SW: 1K0 920 863 A HW: 1K0 920 863 A
Component: KOMBIINSTRUMENT 3HL 1610
Coding: 0021103
Shop #: WSC 24200
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 57851 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:30
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Coding: 3D3F030007001002
Shop #: WSC 00066
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 81
Mileage: 57672 km
Time Indication: 0
Date: 2000.00.00
Time: 15:44:20
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 63
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 57851 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 57851 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:42
Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Coding: 18900A000106087F2D04840560084F01E0FCA0
Shop #: WSC 00066
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 81
Mileage: 57672 km
Time Indication: 0
Date: 2000.00.00
Time: 15:44:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 94
Mileage: 57851 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:43
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.LBL
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Coding: 0000180
Shop #: WSC 00066
2 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Mileage: 0 km
Time Indication: 0
00110 - Right Mirror Turn Signal Lamp (L132)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 98
Mileage: 57959 km
Time Indication: 0
Tuesday,09,February,2010,11:39:38:21461
Chassis Type: 1K0
VIN: WVWZZZ********** Mileage: 116830km/72594miles
42-Door Elect, Driver -- Status: Malfunction 0010
62-Door,Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
Part No SW: 03C 906 056 CG HW: Hardware No
Component: MED9.5.10 00 9268
Coding: 0000072
Shop #: WSC 00160
1 Fault Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
P2015 - 008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 115923 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:36
Freeze Frame:
RPM: 2840 /min
Load: 26.7 %
Speed: 75.0 km/h
Temperature: 84.0°C
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Coding: 01050E2700041800000A00000F00000000095D035C
Shop #: WSC 00066
Part No: 1K1 955 119 C
Component: Wischer VW350 012 0402
Coding: 00063445
Shop #: WSC 00066
5 Faults Found:
02399 - Control Circuit for Terminal 30 for Interior Illumination
Freeze Frame:
Fault Status: 00111001
Fault Priority: 5
Fault Frequency: 3
Reset counter: 192
Mileage: 115501 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 13.20 V
OFF
OFF
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
Freeze Frame:
Fault Priority: 5
Fault Frequency: 12
Reset counter: 179
Mileage: 115679 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.70 V
ON
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 182
Mileage: 115930 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.60 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 192
Mileage: 115501 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.30 V
ON
OFF
OFF
OFF
OFF
00975 - Heated Rear Window (Z1)
Freeze Frame:
Fault Status: 00111100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 182
Mileage: 115678 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.70 V
ON
OFF
OFF
OFF
OFF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.LBL
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0000244
Shop #: WSC 00066
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN2.LBL
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2434
Coding: 0000144
Shop #: WSC 00066
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.LBL
Part No: 1K0 959 704 F
Coding: 0000144
Shop #: WSC 00066
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
End --------------------------------------------------------------------------------------------------
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 57672 km
Time Indication: 0
да, обе на ходу....приехали уехали своим ходом, у них какая то хрень с предохранителями вечно твориться...то ли руки кулибиных, то ли реальные глюки...
