Парктроник на Джетту.
ну здрасьте "не слышал", а это что
http://jetta-club.org.ua/forum/viewtopi ... ight=waeco
waeco это немецкая контора, кучу всего делает и для машинок тоже
название всего ассортимента для машинок начинается на "magic" :oops:
см тут
http://www.truck-comfort.ru/magic/watch
я как - то ставил сам в прошлый поло центральный замок от них, осталось очень хорошее впечатление от изделия
нашел в инете тест autobild парктроников, 2003 год
перевел гуглом с нем на англ
победитель - система от waeco
Bosch park pilot
Price: 360 EUR
Installation: hardly
Sensitivity: very well
Result: the most expensive in the test, very high-quality worked, special installation periods for nearly all vehicles
Judgement: Well
Cobra park master
Price: 229 EUR
Installation: simply
Sensitivity: well
Result: simply constructed, fast inserted, no indicator, must be calibrated
Judgement: Well
Rave EPS Safe park
Price: 99 EUR
Installation: Very simply
Sensitivity: unsatisfactorily
Result: No indicator, announces obstacles the car drives only so long
Judgement: Unsatisfactorily
In pro park Boy IV
Price: 309 EUR
Result: Roll Royce among a park assistance, shows the place on a display in 5 cm steps very precisely
Judgement: Well
Valeo master park master system
Price: 250 EUR
Installation: Simply
Sensitivity: well
Result: Erstausr?stung in many vehicles, no indicator, useless fitting instruction
Judgement: Well
VDO Distance control
Price: 205 EUR
Sensitivity: Satisfying
Result: the plant does not work with two relatively large sensors, in the controller is particularly exact the indicator
Judgement: sufficiently
Waeco MWE 800-4
Price: 189 EUR
Result: In the display an LED per sensor, which changes its color depending upon distance, shines then can the obstacle more easily be located
Judgement: Very much property/price achievement winner
Waeco MWE 850
Price: 198 EUR
Result: Is only starting from February in the trade, indicator indicates the distance relative to exactly the obstacle
Judgement: Well
Waeco MWE 800-4
Price: 189 EUR
Waeco MWE 850
Price: 198 EUR
Judgement: Well
Какая из них победитель))?
Waeco MWE 800-4
это все инфа 03 года
Думаешь щас другие модели?
не знаю, не разбирался... но инфа 03 года :)
я вот рассматривал сегодня задницу пятого гольфа и так и не придумал, куда именно там лепить эти датчики...
Ты лучше порассматривай задницу Джетты(если найдешь ее у вас там) :) Потому как на гольфе, понятнее где бампер заканчивается)))
Если еще интерес не пропал сегодня-завтра сфотаю индикатор в салоне и выложу (сорри за задержку - много работы навалилось)
IgYa конечно сфоткай :)
ну вот как у меня расположен индикаторный блок парктроника (показания читаються через зеркало заднего вида - если прямо смотреть - в зеркальном отображении, это видимо настраивается при установке)
еще добавлю, что парктроник округляет показания "вниз",т.е. 0.4м и далее до 0.5м показывает как 0.4, если меньше 0.4 - показывает 0.3, меньше 0.3 - звучит непрерывный сигнал и буква "Р" (проверял рулеткой)
Все же не думаю, что необходимо мерять еще меньшие расстояния - тут видимо растет погрешность измерения и вероятность вляпаться в неприятность увеличивается. Гораздо важнее, чтоб парктроник четко реагировал на небольшие препятствия, типа трубы - любят парковщики делать из них столбики и прочую хрень, мол место на парковке занято. Один раз наехал на подобную фигню, парктроник запищал токо в самый последний момент. Слава богу обошлось без последствий.
